02-17-2021
09:47
07:16
WilsonFitbit
02-17-2021
09:47
07:16
WilsonFitbit
Hi
I have a Charge 3 and I was wondering if that will support Smart Wake feature?
If not, then which Fitbit devices or products will support Smart Wake?
/M
Best Answer02-18-2021 07:14
02-18-2021 07:14
Hello @Mindraid, welcome to the community forums!
Charge 3 supports Smart Wake. When setting an alarm, turn on Smart Wake. This allows your tracker to find the best time to wake you starting 30 minutes before the alarm time you set. It avoids waking you during deep sleep so you're more likely to wake up feeling refreshed. If Smart Wake can't find the best time to wake you, your alarm alerts you at the set time.
In addition, devices like the Versa 3 and Sense also support Smart Wake. For more information, please check:
How do I manage alarms on my Fitbit device?
Hope this helps!
02-18-2021 07:14
Hope this helps!
