02-16-2014 21:16
02-16-2014 21:16
Why can't fitbit automatically track sleep/wake, like it does for every other activity? Want.
02-16-2014 21:24
02-16-2014 21:24
How would the FitBit know the difference between your sitting to read or watch a movie and sleeping? The tap method works well enough for me and my Flex.
You having trouble with sleep mode?
Best Answer02-18-2014 20:42
02-18-2014 20:42
The fitbit products can't determine if you are sleeping or watching TV. The software needs a switch turned on - the double tap. The question was why can it be automatic? One user expressed his satification with having to manualy enter into sleep mode. I disagee with his assessment that its easy to use, it is most definitely NOT. As another pointed out there is lack of input data to ensure accuracy. The Basis tracker has heart rate monitoring along with perspiration sensors and can determine when the wearer is sleeping. The answer? The Force would need more sensors to do it automatically i.e. Higher Price.
Best Answer02-16-2014 21:24
02-16-2014 21:24
Best Answer02-16-2014 23:05
02-16-2014 23:05
Best Answer02-18-2014 10:43
02-18-2014 10:43
Sleep monitoring with any similar device is just a guesstimate since its based on how much the wearer is moving..... not brainwave patterns, eye movements, etc.
02-18-2014 13:01
02-18-2014 13:01
Best Answer02-18-2014 13:04
02-18-2014 13:04
But its only accurate in conjunction with user feeback...... the user confirms they were sleeping or watching TV between two assigned timepoints.
@Larry48 wrote:
Yes but you infer actions by observations. You can by by summarizing movements predict if a person is sleeping or merely watching TV.
02-18-2014 20:42
Best Answer02-19-2014 17:29
02-19-2014 17:29
Has anyone seen the BASIS tracker in action?
Best Answer02-19-2014 18:50
02-19-2014 18:50
They haven't perfected their sleep tracker or anything else. The Basis forum is full of people having troubles with it.
note: I do not have personal experience with that product, only read about it.
Best Answer03-12-2014 10:19
03-12-2014 10:19
I, too, was frustrated with getting it into and out of sleep mode. Sometimes it didn't matter how much I pounded on it, it wouldn't change modes. Recently, I was reading one of the Flex101 articles about the different ways to communicate with the Flex; problems solved. Tap [vs. "pound"] twice to wake it up. Immediately after the lights stop moving, tap it again several times until the mode changes; usually about the 5th tap is where it will switch into or out of sleep mode, but don't stop until you see the lights change.
Also, as FYI, when you go to sync the fitbit, tap twice to wake it up [see lights], then click sync on the PC or phone.
03-12-2014 10:51
03-12-2014 10:51
Best Answer03-13-2014 13:49
03-13-2014 13:49
I had the One up until last weekend and never had problems with the sleep tracking accept that I hated the wrist band that often came undone while sleeping. I bought the Flex over the weekend and have yet to figure out how to get the thing into sleep mode. I checked the website and followed the instructions there, but it's just not working. I've found the tracking itself (on the One) to be pretty efficient and accurate. I like the fact that if I forget to turn it on/off, I can enter it online and it still shows me how many times I woke up during the night.
03-16-2014 14:40
03-16-2014 14:40
03-16-2014 14:47
03-16-2014 14:47
Best Answer03-19-2014 22:57
03-19-2014 22:57
I just got my fitbit flex for my birthday this weekend and started using it on Monday. I put it in sleep mode last night but was bummed to find this morning there was no sleep log. I manually entered my hours on the mobile app and it populated my sleep pattern for the night. That makes sense since I'm sure there are nights we all forget. So that is always an option!
03-25-2014 10:56
03-25-2014 10:56
As a guy from the IT field, it should be relatively easy to setup the auto sleep function, without any additional sensors. It could just require some more input from the end user. With better sleep habits, we should all strive to get to bed at approximately the same time. WIth the end user adding the normal sleep habit window in as an additional input...this could be combined with the activity state, and used as a layered condition...to determine if the user is asleep.
03-30-2014 09:19
03-30-2014 09:19
Best Answer05-17-2014 14:48
05-17-2014 14:48
If you forget to turn it on, you can do to the sleep tab and and enter when you went to sleep and when you woke up and it will show you.
Best Answer06-28-2014 06:33
06-28-2014 06:33
You just solved my dilemma!!! Thank you!
Now, if I could just figure out after all this pounding if I have turned the sleep mode ON or if I have turned it OFF!!!
07-19-2014 10:52
07-19-2014 10:52
I also have the One and agree 100% with what you said about it Sevierflygirl. I also do not like the sleep band. The clip does not fit in it well and if you take the device out of the clip it falls out of the band (thus can go in the toilet...not good). I wear my One on a piece of leather around my neck and it tracks my sleep accurately when I stop moving around at night and logs any restlessness as awake time, which it probably is. Although I read in the help info that you can put the device into sleep mode by pressing the button and holding it in until the flashing stops, I do not see the advantage to this overall. The other people posting here, I am guessing, do not have the One. I chose it after reading the reviews on Amazon, and have never regretted my choice. I love it! ![]()
