12-21-2015 21:19
12-21-2015 21:19
12-21-2015 22:47
12-21-2015 22:47
It depends on your age, level of fitness, level of activity etc.
Best Answer12-22-2015 05:48
12-22-2015 05:48
Best Answer12-23-2015 00:02
12-23-2015 00:02
@erikab wrote:
I am 33 and have been pretty active at least 30 min of exercise daily. My average steps are14k.
@erikab In medical circles a resting heart rate can be from 60-100. Here is a link from the American Heart Org.
Mine is typically 54-61 and depending on the temperature of the day or an onset of a cold or throat. We had some 100oF days and the RHR increased a point each day as the weather got hotter. I have found RHR accurate on the Charge HR and my Omron Blood pressure Monitor. is withing 1 beat. My HR gets down to 41 while asleep.
If you are concerned I would have your GP check you over.
It's amazing how some simple observations trigger a series of events. I was having my annual series of blood tests the other day and we were talking Fitbit and heart blockers, I have a 1st degree heart blocker and is no concern but, surprise, surprise , the nurse who is in her mid thirties has a pacemaker because her Fitbit showed a very slow heart rate, like every 2.5 seconds and she has has a 2nd degree heart blocker.
Best Answer12-24-2015 05:38
12-24-2015 05:38
A quick search on Google:
A normal resting heart rate for adults ranges from 60 to 100 beats a minute. Generally, a lower heart rate at rest implies more efficient heart function and better cardiovascular fitness. For example, a well-trained athlete might have a normal resting heart rate closer to 40 beats a minute.
12-26-2015 15:21
12-26-2015 15:21
Best Answer12-27-2015 11:34
12-27-2015 11:34
01-01-2016 17:02 - edited 01-01-2016 17:11
I just got a Charge HR last week and notice my heart rate goes down to about 60 when I sleep. But Fitbit says my RHR is about 75, why is that? OK, I see they for some reason want to use daytime data.. but since I rarely sit still, they aren't really getting a resting heart rate!
01-02-2016 03:15
01-02-2016 03:15
I would view the "resting heart rate" reported on the FitBit app with a great deal of skepticism.
When I'm truly "resting" - ie. sitting quietly, not having consumed caffeine, etc. or recently run up a flight of stairs - my heart rate is a steady 71-72 bpm. Sometimes I can sit and watch it rise three or four beats just from the stress of worrying about my resting heart rate.
But according to the FitBit app - my Resting HR is a (dangerous, IMO) 88-90 BPM.
Apparently the algorithm FitBit uses to calculate resting heartrates is based on people who have a different lifestyle to mine.
05-01-2017 11:44
05-01-2017 11:44
My numbers are that high too. They were in the mid 60's when I was walking 4 miles a day, but I decided to try running 5k and hurt myself and haven't worked out in 4 months. It's slowing climbed to increasing about 20 bpm. Plus I've gained 15 pounds. My resting heart rate alone is enough to alarm me back to getting healthy again.
Best Answer07-06-2017 08:23
07-06-2017 08:23
My resting heart rate is 85 bpm, I have read that the normal resting rate is between 60 and 100 but the nearer 60 the better
Best Answer07-13-2017 09:37
07-13-2017 09:37
I just got my fitbit charger 2 today, and my resting heart rate is : 89 or 90 which is considered normal.
Best Answer09-23-2017 10:50
09-23-2017 10:50
Mine is the same, normally high [89-91] but when I go to the gym [4-5 days a week] it quickly goes down to 83-85... need to keep going so it continues to go down because as soon as I stop it goes right back up! My BP is always pretty good though 😁
09-27-2017 10:54
09-27-2017 10:54
I have read numerous sources which say, "While a resting heart rate of 60-100 is "normal", folks with an RHR in the 80-100 range statistically have a much higher incidence of heart related issues than those below 80, in fact, some maintain 70 or lower is best."
09-27-2017 19:23
09-27-2017 19:23
Accordingly to Fitbit, my resting heart rate is from 50 to 53, to me is normal. I exercise 6 times a week.
Best Answer01-09-2018 22:00
01-09-2018 22:00
I'm 52 and my resting rate is usually 80, i feel fine and have low wieght. So I wouldn't worry, your in the accepted range.
Best Answer10-05-2018 14:25
10-05-2018 14:25
My fitbit tells me my resting heart rate is 69 to 71 when I wake up. I'll monitor my heart rate with the fitbit throughout the day and it ranges from 79 to 98 depending on what I'm doing, But even if I'm at my desk and typing away my heart rate will stay in the high 80's to low/mid 90's. Not sure if sitting, typing and talking on the phone is considered resting but it does bother me that I'm not in high 70's low 80's during this time. I'm 59 years old..
Best Answer10-05-2018 17:06
10-05-2018 17:06
@stendeln RHR is just that., when you are at a state of rest and still, as detected by your Fitbit.. This link will help explain and your pulse rate is within the guidelines for resting HR.
After you sync, what is the RHR on your Dashboard.?. The PC Dashboard is normally 1 bpm higher because of their rounding.
@stendeln wrote:My fitbit tells me my resting heart rate is 69 to 71 when I wake up. I'll monitor my heart rate with the fitbit throughout the day and it ranges from 79 to 98 depending on what I'm doing, But even if I'm at my desk and typing away my heart rate will stay in the high 80's to low/mid 90's. Not sure if sitting, typing and talking on the phone is considered resting but it does bother me that I'm not in high 70's low 80's during this time. I'm 59 years old..
Best Answer10-14-2018 19:24
10-14-2018 19:24
I have the same resting rate as you. I have something called postural orthostatic tachycardia which means my heart rate drastically changes depending on whether I'm sat or stood, in a hot room or outside, etc. Any simple change can trigger it to be honest!
I'm not trying to scare you, just explaining the reason behind my numbers.
If you get palpitations at all or feel dizzy, you need to get checked out by you gp.
If you see my picture, my rate goes haywire just after the gap which is when I had a shower. The heat changing is the worst for me!A typical rest day for me.
Best Answer10-14-2018 20:25
10-14-2018 20:25
@stendeln The important thing is your body as @FlossPops posted.. Any signs of giddyness etc..... Off to your Doctor..
