01-22-2015 22:01
01-22-2015 22:01
so I've only had my charge hr for 3 nights now...
first 2 nights were fine, 7 ish hours (which is correct as I also use "sleep as android")
but upon waking I checked last nights data and it says I only slept for 3hrs... o.O?
what gives? I definitely went to bed at 9:30 ish and woke up at 5:30 ish
ideas? help?
Best Answer01-22-2015 23:18
01-22-2015 23:18
It is possible you could have accidentally bumped it out of sleep mode while you were sleeping or getting up to use the bathroom. I have noticed my Flex will go into sleep mode if I'm pushing a shopping cart around the store (because of the vibration, I think). Fortunately, I feel it buzz when that happens so I can fix it right away. I don't know how different a Charge is from the Flex, but I'm hoping it's a simple explanation. If not, I have found Fitbit customer service to be excellent! Have fun. 🙂
Best Answer01-23-2015 01:35
01-23-2015 01:35
I didn't realize I could turn it on and off.. it's automatic.
but discovered that by manually editing the times from dashboard it still shows a somewhat accurate graph with correct times... strange
