07-29-2019 14:40
07-29-2019 14:40
I damaged one surge from excessive moisture. It still works, but won't swipe, etc. I have bought a used/second surge for my daily wear.
Is there any way I can keep them both connected to my account? When I set up the new one it seemed to make me "replace" the original. I'd like to keep the original for backup use when I'm out working in humid/hot/rough conditions.
Paul
Best Answer07-29-2019 17:28
07-29-2019 17:28
Hi @Proctoidpaul - Sorry, but you can only have one Surge on your account at a time. In order to switch from one to the other, you will have to go thru the replace process. It’s not that bad. I do that when switching back and forth between my Inspire and my Versa. Just be sure to sync first!
07-29-2019 17:28
