07-29-2019 16:10
07-29-2019 16:10
Can I manually add exercise that my Surge did not register?
Best Answer07-30-2019 11:11
07-30-2019 11:11
Welcome to the forums!
Of course you can
Computer: Go to the Log then activities. Scroll to the bottom and search for the exercise. Add the info and that's it
Phone: Tap the exercise tile. Tap the Gear, Search for the exercise and add info
If it isn't listed you can add a custom exercise. When that's the case I use workout mode then rename after it sync
Wendy | CA | Moto G6 Android
