24h vs AM:PM
ANSWERED
How can I change the clock to be 24h one instead of am:pm clock? Can I add 3 different time zone? (New York, Paris and Bangkok for instant)
I will appreciate any answer.
Cheers
1 BEST ANSWER
Accepted Solutions
@Morput To change to 24 hrs. Go to your Dashboard and click on the gear in the upper righthand corner. Click on Settings. The screen should be on "Personal Info". If not select it. Scroll down to "Clock display time". Select 24 hour. Scroll down to blue "Submit" button and click. Finally sync your Surge by using FitBit Connect or the FitBit App. I believe you can select an available time zone from the list I don't know if you can "add" any. Good luck.
Fixed wing aircraft (F-4J, F-4S), Fighter Squadrons: VF-171, VF-31, VF-103.
1 REPLY 1
