07-18-2017
23:12
09:29
YojanaFitbit
07-18-2017
23:12
09:29
YojanaFitbit
I wear my surge on my left are and find that during boxing session the buttons on the right of the face are regularly 'triggered' by my gloves or mits especially when dropping down to do 'burpees', pushups etc. I have worn the surge higher on my arm however it is a little uncomfortable and tends to slide when I work up a bit of a sweat. Can a 'lock' function be added to the surge to disable buttons or alternatively a 'training bracket' made to clip over the surge to stop buttons being hit. I could wear it on my right arm however there are buttons on the left also.
I'm glad to see you here in the Forums @ShaneBo, your comments are very important for us! ![]()
A way to lock your Surge while doing an activity is an excellent idea and I would like to encourage you to vote and place your comments in this request that was already suggested here: Lock buttons while in exercise mode, members of the Community can place new ideas in this board so they can be implemented in a future update, this is the best way to make your voice heard.
In the mean time I'd recommend you wear your Surge a little bit loose when you have it higher in your left wrist, so the button will be facing up. I hope this you can use your Surge in your boxing sessions, give it a try maybe with time will be less uncomfortable.
Hope this helps! ![]()
