I forgot to turn the walk off using GPS so now it shows my drive home as part of the walk on the maps. Can I fix that. Any way to adjust the time walked
Ooops! Did you track this walk as a discrete activity or was the Surge recording it automatically?
Either way, I think you need to manually enter the data for the two separate phases - actually walking, and driving. I think you should then be able to delete the entry that covers the combined activity, if the Surge doesn't do that for you by removing the duplicate steps.
If that doesn't work, customer support may be able to alter your record for you.
Hilary | UK
Charge, Aria, iPhone 4s, Mac
If this answer is helpful, please vote for it and/or mark it as a solution.
