10-17-2016 20:36
10-17-2016 20:36
04:24
05:13
10-19-2016
04:24
05:13
It's great to see you around @Jewjew. Please confirm you are doing the following to set your alarms from your Android Fitbit app:
1. Tap Settings
2. Tap Alarms
3. Tap the "+" icon in the upper right corner
4. Enter your information
5. Tap Save
6. Sync
Since if you are following these steps you should be able to see an image like the following, where the AM and PM are visible:
Hope to hear from you soon. ![]()
Best Answer10-23-2016 06:47
10-23-2016 06:47
06:20
05:12
12-04-2016
06:20
05:12
@Jewjew Thanks for your reply! That is very strange! It should let you change from am to pm with no problem. I recommend doing the following:
Try that out and let me know how it goes! ![]()
