08-17-2016 02:10
08-17-2016 02:10
I got my Surge as a Xmas present imported from the US in December 2014 and have worn it almost continuously.. It has suffered from the cracking on the back around the screw holes but hasn't failed at that point. Yesterday the buckle pulled through the wrist band- I've now carried out a rapid work around with duck tape but I'm looking for recomendations for a replacement. My principal activities are spinning and hiking and I find the existing facilities in the Surge very useful however I don't use the GPS function as I have full size units which I use when walking. I'm open to suggestions from across the range of manufacturers - the Garmin Vivoactive seems just too clunky and too expensive - is the Blaze a suitable replacement as I don't want to pay for another expensive Surge with this type of design fault? Any ideas are most welcome 🙂
08-17-2016 12:08
08-17-2016 12:08
Welcome to the forums @rossorichie
You can do a comparison here - click
Looks like the Blaze does everything the Surge does, just without the GPS tracking.
I've had one since they came out and love it. It's a tad bigger than the Charge HR, but it's still sleek looking with a great feel.
08-17-2016 13:53
08-17-2016 13:53
I also love my Blaze the the ability to change the bands
I agree its a good replacement for the Surge
Wendy | CA | Moto G6 Android
08-17-2016 23:16
08-17-2016 23:16
@rossorichie wrote:the Garmin Vivoactive seems just too clunky and too expensive -
too expensive ?
$20 more
different functionnalities
Best Answer08-18-2016 00:29
08-18-2016 00:29
08-18-2016 00:38
08-18-2016 00:38
Thanks for the suggestion but I'm UK based and the Surge is well out of warranty - whilst the failure is disappointing I'm marking it down to experience. I'm surprised that fitbit don't do a repair service or at least supply a new band as replacing it (inc any bonding required) isn't beyond the capabilities of many people.
08-18-2016 00:44
08-18-2016 00:44
I'll take another look as many seem to be giving it the thumbs up - my comments on the pricing were incorrect as I seem to have book marked the wrong model - doh!
08-18-2016 06:59
08-18-2016 06:59
@rossorichie It's great to see you in the Community! So sorry to hear about the issue you experienced with your Surge. However, my friends @WendyB and @Odyssey13 advised great in regards the Fitbit Blaze as an option. My best advice is to contact our Customer Support team so they can take a look at your case and review your warranty and options.
@ajakubisin @SunsetRunner I really appreciate your feedback my friends since it helps us to keep improving and provide a better service since it's our main goal.
I'll be around if more questions arise! ![]()
02-27-2017 19:55
02-27-2017 19:55
I am also looking for another alternative to my Surge. Since I got my first Surge in 2015, it began falling apart at the screws, as you observed, but I called them, and they sent me a replacement as it was still under warranty of 1 year. The replacement had the exact same thing happen to it, in less that one year, they finally sent me another replacement for that one, and now I've barely had it since November and the screen just went dead. The screw holes haven't ripped just yet though ....
Obviously the quality control for the Surge does not correlate with it's price point. I'm looking into the Garmin.
03-01-2017 03:45
03-01-2017 03:45
@teeroks Thanks for joining us in this thread and our Fitbit Community! Seems odd that your Surge's display is not turning on. I would like you to try restarting it as advised in Meylin's post. This will refresh your tracker internally and check out if your Surge's display gets back to life.
Looking forward to your response my friend! ![]()
03-01-2017 08:25 - edited 03-01-2017 08:26
I already did a reset on the device and had the same issue. I am not new to fitbit, have had this device for nearly a year and half, and this is my third replacement device. If they werent tearing by the screws, or water getting into the screen (mind you, I have never showered once with the device and always keep it clean) then now it's the screen going blank. There is a quality control issue with this device, hands down. It costs 250 bucks and doesn't even last a year? That's just not cool, and I felt it important to share that. Don't get me wrong, the intentions are great. I love what the device can do......when it actually works and isn't falling apart.
03-01-2017 09:53
03-01-2017 09:53
Yeah you got the generic cheerfull standard crappy advise from fitbit. Starts to get annoying after a while. Garmin have a far superior range of long lasting products
03-01-2017 10:12
03-01-2017 10:12
I managed to extend the life of mine by using a thin strip of rubber taken from a old bicycle inner tube bonded with some rubber adhesive in order to fix a broken buckle strap - not pretty but it works.
Best Answer03-02-2017 08:36
03-02-2017 08:36
Yeah I am going to look into switching. I love the integration of fitbit with the other apps, but when it comes down to it, i guess it doesnt really matter. I just get pissed when company's dont care they sell crappy products.....like, do better.
11-05-2017 07:30
11-05-2017 07:30
My surge the band came off I am lucky that didint Lose it. I toké it to Best Buy they said they would not received and told me to write to fitsbit. I have been a user for almost 5 years and this is my 4th fitsbit. Tell you want me to send to you? Or you will send a replacement?
Best Answer11-05-2017 09:44
11-05-2017 09:44
Welcome to the forums @Irving
If you're within the one year warranty and it was purchased from an authorized retailer, contact customer support at this link - click
There is a phone number for the USA, an online chat option and web based email for those out of the area.
Keep us informed.
11-06-2017 01:22
11-06-2017 01:22
@Irving Amazon and E-bay sell aftermarket bands for the Surge. YouTube has "How to" videos to help if you're interested. Good luck.
11-06-2017 02:13
11-06-2017 02:13
