Hey, @Tao75 nice to see you again! This is the first time I hear something like this. I'd like to know if you're using your native Android player or another app. Are there any other Bluetooth devices nearby? Something like headsets maybe? And last but not least, please try to turn your Bluetooth off and then turn it back on.
Le me know if this helps!
Hello there @Jubed! Allow me to help you with this. I'd like to know if you already tried to disable and enable your notifications and music control, to do so:
I also want to share a list of app that work with Surge.
-Samsung music app
-LG Music app
-Rdio
-Amazon Music
-Spotify
-Play Music
Currently Pandora doesn' work with Surge.
Let me know if you need more help.
Thanks for the update @Tao75! Currently the Sony Z5 is not included in our list of supported devices. I recommend keeping an eye on this list and check for the updates.
Good luck!
Best AnswerI've got a z3 compact with the same issue, and it is on the list of compatible devices, specifying music. Sony's "Throw" app turns on and the fitbit suddenly says "connecting". I've followed the forget device instructions as well.
Great to see you around @Tao75 and @imagine002 welcome to the Community! I would like to know if you keep having problems connecting your tracker with your phone? If you do, I recommend checking if your phone is on our list of compatible mobile devices, if it is not there that's the reason why you are having problems connecting your tracker with your phone.
If your phone is there, check the Surge (classic) won't sync for music control post, where our friend @DerrickS is providing some good troubleshoot to fix this inconvenience.
I hope this helps, let me know the outcome. ![]()
Best AnswerYes, Moderator seemed to miss the point. We mentioned out phone models, and as I mentioned specifically, it is in the supported device list. And as we'd mentioned, we'd already paired. After they are paired (following the instructions linked), that is when the issue arises. It appears the "Throw" software on Sony phones (those on the "supported list" and those not) interferes with how the Fitbit and the phone communicate with each other in some way.
The minimum effort would be to update the Supported Devices list to accurately reflect the Sony phones not supported. The real solution is a software update.
09-14-2016
06:26
17:50
09-14-2016
06:26
17:50
Welcome to the Community @SalvorHardin and it's great to see you around. Thanks both for your feedback, I recommend doing the following:
If you keep having problems, get in touch with our support team for further assistance. For a faster response you can contact them via phone or chat.
Catch you later. ![]()
Best AnswerI fixed this! 100% fully fixed!
I sold my Fitbit.
Job's a good 'un. If they can't even understand being told "this is a fault, this is how to reproduce it, please advise", then sod it. Not worth the hassle.
