05-25-2017
13:33
09:03
YojanaFitbit
05-25-2017
13:33
09:03
YojanaFitbit
I have had one band break away from the screws on the back of the watchface after 13 months of wearing and then a second Surge band that pulled away from the face on the top and bottom of unit within 3 months of receipt. This is very upsetting for the amount of money charged. I wish Fitbit would stand behind their product. Spending $250 on a tracker should provide a quality product that lasts far longer than 2.5 months.
HI @TJThomson! Thanks a million for your feedback! I can see that you're new in the Forums, Welcome! ![]()
I appreciate your comment, after checking with our Support Team I noticed that you got a response from them. Please confirm if they already responded to your inquiries, since as you mentioned your Surge was already out of warranty. I'll be happy to check this information for you!
Have a good day! ![]()
Nice to see you here again @TJThomson, please check your PM inbox as I've sent you a Private Message to follow up your case!
Keep up the good vibes! ![]()
