It's nice to see you around @Mantis_arm
! I'd recommend checking and following @RoDo's suggestion in this post.
Give it a shot and see if that does the trick too!
Best AnswerNew Surge now on day three, I have exact same issue that Surge will not pair with my iPhone SE,
Some times iPhone SE Bluetooth pairing displays Surge (Classic) other times "Surge". What is really annoying is the time out on the Surge device. Frequently when Surge device set at "Pair" and sometimes a pairing code is displayed only soon to discover that the Surge Bluetooth Classic device displays OFF.
As a Windows 10 desktop and Windows 8.1 Tablet user each device discovers the Bluetooth device "Surge Classic" end I find that the end result is always a display message "That didn't work. Try again and make sure the device is discoverable". Come on fitbit improve your device please?
Best AnswerFollow on; With iPhone SE displaying Now discoverable as "iPhone SE" and Surge device set "Bluetooth Classic PAIR" three minutes later Surege device displays "Bluetooth Classic OFF" why?
Thanks for trying @Casique
I'd recommend following @DerrickS' steps that he shared in this discussion.
Hope that helps!
09:13
09:57
07-04-2016
09:13
09:57
I followed the links you proposed. The direction destination had no solution
Moderator edit: Removed personal information
Best Answer@Casique Surge Clasaic is strickly used to control music on a phone, there is no reasin to pair it to your computer.
For the Surge Low Energy Bluetooth, this is what your Fitbit data syncs through, and must be setup through the Fitbit Software. Once it is setup and attached to your account the software will then pair the Surge to the computer or phone.
Does the Surge sync your data to Fitbit.com?
Dor music control the link above should help out
