02-04-2017 12:30
02-04-2017 12:30
I have a Surge that I have had over a year now, it has been a good unit other than the light stopped working after a few months.
I know I am out of warrenty but wondering the cost of having the internal plug of the charge port repaired?
One side of it broke off and one of the contacts fell out, so now I can not charge it.
Thank you for any info.
Don.
02-04-2017 13:15
02-04-2017 13:15
Sorry, but I am not aware of any repair services for your tracker. 😞
02-06-2017 06:55
02-06-2017 06:55
Hey @DonaldB, thank you for joining us! ![]()
Sorry to read about your little buddy, as @SunsetRunner said we don't have any information of a place you can take your Fitbit to be repaired. Our best recommendation is to contact our Support Team, even if your Fitbit warranty is already expired, they can give you some good points if you're considering keep using Fitbit products. You can reach them via email, or if you prefer you can chat or calling them at:
Keep me posted with the outcome! ![]()
Best Answer02-10-2017 13:27
02-10-2017 13:27
mine broke as well after just a few months, but since this one was already a replacement for my original tracker, the support team wouldn't replace it since my original warranty ended....apparently warranty period is only on the original tracker, not the replacement...which I think is horrible. a replacement tracker should have a warranty too! let me know if you were able to fix yours!!
02-10-2017 18:08
02-10-2017 18:08
Best Answer03-31-2017 12:29
03-31-2017 12:29
Also happened to me. My second Surge (replacement)has only lasted 5 months. I do NOT recommend the Surge. Now that the original warranty is expired - no replacement offer.
