01-07-2016 02:55
01-07-2016 02:55
Hi - new user of Surge. Somehow (probably user error on my part!) I appear to have a daily target of 4,100 calories.... how is this determined or set?
Best Answer01-07-2016 04:48
01-07-2016 04:48
Best Answer01-08-2016 06:24
01-08-2016 06:24
Great thanks, found the space on the app to change the targets but the calorie traget wont change (floors, steps targets can change the graphs change too). I've even set weight loss to "maintain" and it is still showing i need to burn 4,100 clas p/day. I did (ma be the answer) sign up to premium and use the "trainer" tab - selecting a level of activity so it might be set by this (don't know) but since then when I click the trainer tab now on the site it takes me straight back to the Dashboard.
Am I going round in circles?
Best Answer01-08-2016 06:37
01-08-2016 06:37
The trainer tab will indeed send you back to the dashboard -- you need to complete your first session (I forget if it is one month or six weeks) and then it will reset your trainer goal, or you can reset in the meantime (click on the trainer and then the gear icon)
