Can I charge my tracker every day?
Can I charge my Fitbit everyday(to keep the battery topped off), or will this lower the battery life of my Surge?
1 REPLY 1
As with any lithium battery, there is a life cycle. The worst thing you can do is let it completely run down. Daily charging seems excessive though unless you are using the GPS function daily for a long time. I would suggest every 2-3 days otherwise.
