Hi, @Charliesass , it sounds as if you have added both devices to your account. Your wife will need to have her own account. Assuming you want to use the same tablet for both accounts, you should remove the Charge from your account (click on charge and choose remove), then you will need to log out of the app (go to account and scroll down to the bottom to log out). Next your wife will need to select "Join Fitbit" to log in and create her own account. She will then need to add the Charge to her account, following the on screen instructions. During this process you will need to make sure that your Surge is quite far away (at least 30 feet or perhaps outside in the car) or else the bluetooth signals from the two trackers could cause interference which might make detection difficult.
