12-19-2016 17:26
12-19-2016 17:26
I have a new Surge Fitbit that I want to start using in place of an earlier model that stopped working. Yet, when I try to register the new one I can't do it because I get the message that there is already a Fitbit registered under than email address. How do I get rid of the old one so I can start using the new one (the Surge)?
12-20-2016 01:52
12-20-2016 01:52
It sounds like you are trying to set up a new fitbit account. You don't need to do this. Just logon to the app / computer using your existing fitbit account and then take the option to add a new device. It will ask if you want to replace your existing fitbit. Just say yes and follow the prompts. All your data, badges, settings etc will be retained.
12-20-2016 06:00 - edited 12-20-2016 06:00
Thanks for popping by the forums @Cheryl1, it's great to have your here! Adding to the information that @SteveH provided. In case that you're using "Fitbit Connect", you will find the option in your PC in this way (for old versions):
If you're using one of the newest computers, you can download the Fitbit App. If you prefer instructions using a mobile device, let me know.
Have a great day! ![]()
