03-11-2016 13:33
03-11-2016 13:33
I used to be able to record treadmill runs on my Surge, by doing the following: click Left, which shows Run. Swipe in some direction (forgot which), and get to Free Run, swipe some more - get to Treadmill. Press Lower Right - chrono starts running.
Now I cannot get to Treadmill at all, only Free Run.
What happened? Why can't I find Treadmill any more?
03-17-2016 20:13
03-17-2016 20:13
I let the Surge run out of power, and when it came back it had all the options, including Treadmill.
Not sure why anyone here did not suggest a reboot, which would probably have helped as well.
Best Answer03-12-2016 03:45
03-12-2016 03:45
It's great to have you here @RdMn! The steps you are following are correct, I tried it with my Surge. I'm wondering, are you only missing this option on your tracker? Are you getting any other messages or errors when you try to find this exercise option?
Looking forward to your reply.
03-12-2016 16:31 - edited 03-12-2016 16:45
@Mcore There are no error messages. When I get to the Free Run screen, I cannot swipe in any direction. (I believe I used to get to Treadmill by swiping right?) It's as if that option was never there.
Is there a configuration option (either in the app on on the website) that allows me to specify that running should include options for both "Free Run" and "Treadmill"? I have found the menu for "auto-recognized exercises", but Treadmill is not there. The page says that "running is always included".
Is there a way to "reboot" the watch?
Best Answer03-14-2016 04:27
03-14-2016 04:27
I appreciate your reply @RdMn. To answer your questions, the Free Run and Treadmill options will appear on the Surge by default, so there is no way to disable them manually. If you are still experiencing the same issue, please get in touch with customer support so they can get you back on track.
I wish you the best. Please let me know if you have any other questions or comments.
03-17-2016 20:13
03-17-2016 20:13
Best Answer03-19-2016 04:17
03-19-2016 04:17
That is very interesting and actually the first time I hear this happening. Thank you for sharing your workaround @RdMn. I'll keep it in mind in case someone else reports this issue. Hopefully your Surge continues to work as normal.
If you notice any other issues, please feel free to post back. Have a great weekend! ![]()
08-26-2018 07:18
08-26-2018 07:18
my surge does not allow me to select treadmill run. after charging fully can swipe once. then no more. do i just need to clean face or just toss fitbit for garmin or other?
08-26-2018 08:05
08-26-2018 08:05
08-26-2018 16:28
08-26-2018 16:28
There are two methods of rebooting the Surge..
1. Push the left and right hand button simultaneously for a few seconds until the screen goes blank and then it will restart.
2. If you can still swipe the screen, swipe to Settings, swipe until you see Shutdown, then follow the prompts. restart by pushing the LH button.
08-28-2018 13:41 - edited 08-28-2018 13:49
Hey @slorunnr, welcome to the Family! Thanks for your help @RdMn and @Colinm39. ![]()
Thanks for reaching out the Forums and for the steps that you've tried to solve the issues with your Surge. You have some excellent steps to try there! If this didn't resolve the issues with your Surge, you can also consider forget the device from the App and reconnect it to your account; you can check the steps here. I’ll be more than glad to lend you a hand with that!
Please keep me posted!
08-29-2018 08:07
08-29-2018 08:07
I restarted watch several times. I see treadmill on watch fine. I just cannot swipe it over to activate this function. Others (free run) work fine. I am letting the battery discharge and then recharge it to see if it works. Until then, my older back-up fitbit keeps me going (slowly). Thanks, Jeff Lakritz
08-30-2018 15:00
08-30-2018 15:00
Thanks for getting back @slorunnr, and for adding those detail on your post. Really helpful. Additionally to the steps that you want to perform, I'd recommend to try these steps too; but if this doesn't help, let me know so I can keep assisting you with that.
I'll be around. ![]()
