05-27-2016 06:55
05-27-2016 06:55
I'm trying to decide between size small and large, and I'm having difficulty because I'm finding some conflicting information.
This help page says:
My wrist measures 6 1/8" at the wristbone and 6 3/8" slightly above the wristbone, so that would mean I'm well within the small range, and a large might be a bit too big.
However, the printable sizing guide says:
That puts me right on the edge between small and large, and Fitbit says they recommend choosing the larger size if you're between sizes.
If I actually use the printed measuring strip, I'm a few millimeters inside the small range at my wristbone, and a few mm into the large range above my wristbone.
What size would your recommend for me? I definitely don't want it to be too tight, but I'd rather not have too much extra band length either.
My local Target carries Fitbits, and probably a few other chain stores near me. Are there any stores that will let me try a Surge on before I buy it?
Best Answer05-27-2016 13:11
05-27-2016 13:11
Im in the middle also, the smallneeded to be on the 2nd to last hole, and would not properly latch. I opted for the Latge amd am happy i did.
