12-30-2016 20:33
12-30-2016 20:33
Why are there two (2) dashboards (page 22, online manual)?
- FitBit.com dashboard
- FitBit app dashboard
What's the difference between the two? How does one decide which dashboard to use? Is it a matter of using 'either or', or do they actually serve different purposes? I could not find any such clarification in FitBit's User Guide/Owner's Manual. Am I the only one confused by this?
Best Answer12-30-2016 23:49
12-30-2016 23:49
The Fitbit.com dashboard is loaded as soon as you log in to fitbit.com computer
Phone. Click on the link at bottom called dashboard and it will load as well.
They are the same so it does not matter which you use.
Wendy | CA | Moto G6 Android
12-30-2016 23:49
12-30-2016 23:49
12-31-2016 13:36
12-31-2016 13:36
Best Answer01-04-2017 13:23 - edited 01-04-2017 15:36
@WendyB amazing explanation! @leighca thanks for you question! The dashboard.com is the one you use in your computer and the mobile dashboard is the one you use form your mobile device. Hope this makes sense! ![]()
Did you receive the answer you were looking for? Mark the post as an accepted solution! 🙂
Best Answer01-04-2017 19:37
01-04-2017 19:37
Best Answer01-05-2017 06:22
01-05-2017 06:22
@leighca it's great hearing back from you! Actually, from your Fitbit.com dashboard you can check how long ago you have synced and the syncing circle is visible there too. Go to your Dashboard and click the gear icon next to your profile pic; there you'll see how long ago your tracker synced. Just like this:
I really hope this makes sense. Just out of curiosity, are you using the Fitbit app for Windows 10? Do let me know!
Best Answer01-05-2017 09:56
01-05-2017 09:56
14:10
08:39
01-08-2017
14:10
08:39
@leighca thanks for stopping by! Now, would you let me know if you updated your Windows computer to Windows 10 or was it already a Windows 10 computer? If you updated your computer to Windows 10 make sure that you're using your Dongle to sync your tracker!
I'll be looking forward to your new comments! ![]()
Best Answer01-08-2017 20:32
01-08-2017 20:32
Best Answer01-11-2017 13:31
01-11-2017 13:31
@leighca thanks for getting back to me! I highly appreciate you clarifying that info.
So that means that you are using the Windows app instead of the Web version of the Dashboard, right? I'd like to know if your syncing process is going seamlessly as it should. Do let me know, I'll be around! ![]()
Best Answer01-11-2017 19:44
01-11-2017 19:44
Best Answer01-12-2017 14:35
01-12-2017 14:35
@leighca I see! Thanks for clarifying. In this case, it sounds to me that your tracker is only syncing to your Windows 10 app since your computer is Bluetooth capable. In order to sync to the Fitbit.com Dashboard you need to use the Dongle. Perhaps that's the reason why. Try it and let me know how it works! However, I'd say to only use the Windows 10 app or the Web version of the Dashboard to sync, as you don't need to open both. Hope this helps. Happy stepping!
01-12-2017 15:05
01-12-2017 15:05
01-12-2017 15:29
01-12-2017 15:29
@leighca you're very welcome! I'm always happy to help here.
Let me know if you have any other inquiry, I'll be around!
01-12-2017 19:29
01-12-2017 19:29
Best Answer01-15-2017 14:11
01-15-2017 14:11
@leighca I also encourage you to visit our Discussions section. In there you'll find lots of interesting topics and be able to make Fitbit friends! It's a lot of fun, too!
Best Answer01-15-2017 14:35
01-15-2017 14:35
01-16-2017 12:27
01-16-2017 12:27
@leighca you're welcome! See you around.
