Walk not listed
ANSWERED
Hello everyone new to the boards just got my charge 2 for Xmas and loving it.
I have the auto detect turned on for everything. Sometimes when I go for a 2 mile walk it does not a show up as exercise only active minutes. I searched and found where I can manually track. But when I use the button to go to the exercise mode. Then tap through the list, walk it not listed. I have treadmill, bike, run, weights, workout, elliptical and interval workout, walk is not listed but is turned on for auto detect.
Why can I not see walk in the exercise mode?
1 BEST ANSWER
Accepted Solutions
Hi, @Russhughes! You need to go into the tracker settings in your app (under account) and edit your list of activities. You can have up to 7 listed, so remove one that you aren't using and replace it with walk.
MakMak | Community Council
6 REPLIES 6
Thank you you very much
Does anone ahve the answer in idiot proof steps how i change the run setting on charge 2 to walking mode, i can see wLking on the app dashbord but cant get this onto the device,???
I'm having the same issue, except when I go into "Exercise Tracking" under the Account menu, the only available options are Voice Cues.  Is there another location I should be looking?
In the fitbit app select account then select your device. Scroll down to exercise short cuts. You can have up to 7 selected. Select the ones you want in your preferred order. After it sinks should be good at go.
Sent via the Samsung Galaxy S7 edge, an AT&T 4G LTE smartphone
Thank you, that fixed the problem.
Sent from my iPhone
