04-09-2016 18:03
04-09-2016 18:03
Is there a way to download our stats eg. our running split times etc.
I know you can download a tcx file, but I don't think that is what i'm wanting.
I just want to see a list of all my Km's and my times. I do screen shots, but have to do 2 or 3 screen shots to get it all.
Cheers
Sam
04-10-2016 12:55
04-10-2016 12:55
@Jacko1975 Welcome to the Fitbit Community! You can download the TCX file for each activity and that will show all the data. The other option is available when you have the premium membership. With that, you can export all of your activities altogether for an specific period of time. You can export it on a CSV file or an XLS file format. This is how it looks.
See you around!
Best Answer01-08-2017 12:56
01-08-2017 12:56
How does one do that and also what is the file? Is it compatible with Excel for instance?
Best Answer01-11-2017 06:44
01-11-2017 06:44
@Phenix0252 Thanks for joining the Fitbit Community! You need to go to your online dashboard settings data export. Once there, you will be able to select the data you want to export.
Yes, it is compatible with Excel, just make sure you select the XLS option under the file format just as the picture I left above.
Try it out and let me know how it goes! ![]()
