01-10-2017 05:44
01-10-2017 05:44
Hi, did workout yesterday and used the surge to record this however when I checked my activity on the phone app it did not record this activity?
01-10-2017 06:15 - edited 01-10-2017 06:16
Welcome to the Forums. Thanks for taking a break from stepping @Crispy_bits! Ups! Is this the first time that it happens? Please check when was the last time that you Fitbit Surge synced with your Fitbit Account, you can do so by openning your Fitbit App > Account > Surge. I would like to know also if you're tracking that activity with the automatic recognition option (SmartTrack) or using the GPS from Multi-Sport section. This information is really helpful to determined what happened in your case. ![]()
I'll be waiting for your response! ![]()
Best Answer01-10-2017 06:32
01-10-2017 06:32
01-10-2017 06:58
01-10-2017 06:58
Thanks for replying back @Crispy_bits! Got it thanks for the details, if you're using Strava please check this post to have more information on how they work togheter, I would recommend trying those suggestions for your exercise.
Please keep me posted on the resolution! ![]()
Best Answer01-10-2017 07:14
01-10-2017 07:14
01-11-2017 06:54 - edited 01-11-2017 06:56
Thanks for replying @Crispy_bits! Sorry about the misunderstanding. It sounds like a syncing or hardware issue then, please restart your tracker a couple of times and make sure that your Fitbit is currently syncing. Your Fitbit should be recording as normal. Surge uses SmartTrack (automatic recognition) or Shortcuts from the Multi-Sport section by choosing the exercise on the Surge screen and both should be showed on your Dashboard in the Activity History.
In case that it is still not showing your exercises please contact Customer Support, so they can further investiage.
Give it a try and let me know if that works!
