02-13-2018
12:50
11:14
YojanaFitbit
02-13-2018
12:50
11:14
YojanaFitbit
There is a LOG menu in which I found activity history and details in fitbit.com but I could not found the same log menu (activity history) in mobile app.
02-15-2018 11:12 - edited 02-15-2018 11:16
Nice to see that you're digging into the Forums @tikicik, let me give you a warm welcome to our Community. ![]()
Thanks for posting your inquiry here! Exactly! Fitbit has different views depending what device you're using. If you're using the Fitbit App on the computer you will find the logs in a different way, as you can see in the picture below. But they have basically almost the same information. You can find more details about it here.
Same thing with the Fitbit App for Android, iPhones and Windows devices. In case that you have any other question, please let me know.
Have a good one! ![]()
02-17-2018 11:34
02-17-2018 11:34
What I seek exactly is below. I found it in fitbit.com (windows) through: dashboard / log / activities /Activity History / View Details / Exercise Details -Kilometer Split. I want the same function in mobile app.
02-20-2018 05:08
02-20-2018 05:08
Thanks for getting back @tikicik! You're right Fitbit Dashboard view from mobile devices are slightly different from the Fitbit.com Dashboard. Which one is the information that you can't see on your mobile device?
I'll be around!
