11-07-2017 18:30
11-07-2017 18:30
Walk mode is not coming on Exercise Tab of my tracker Surge? Can anybody help?
11-07-2017 20:13
11-07-2017 20:13
Welcome to the forums!
You need to go to your dashboard and under settings scroll to exercise shortcuts. You can choose up to 7 and then arrange them if you want. Just put a check mark in the ones you want
Wendy | CA | Moto G6 Android
11-07-2017 20:13
11-07-2017 20:13
11-08-2017 09:42
11-08-2017 09:42
Thanks for the advise.It worked.
11-08-2017 09:45
11-08-2017 09:45
01-13-2018 03:23
01-13-2018 03:23
Hi Wendy b
I've done that bit how do I use it on the surge when i select my exercise then the tick it brings up the clock. But when i select play nothing happens
