03-31-2017
17:39
10:45
YojanaFitbit
03-31-2017
17:39
10:45
YojanaFitbit
and I cannot set a move reminder.
When the band finally wears out on my fitbit instead of investing any more money into a new band, I guess I will need to switch to the apple watch.
I have had many fitbits in my time and a customer since the first fitbit came out. To know I spent top dollar and Fitbit still hasn't updated the software is a bit frustrating even though the customers have been requesting it for years.
Moderator edit: Clarified subject.
You have everything that was promised to you when you bought it. Just because newer trackers have the move feature and a couple older ones (not as old as the Surge) got firmware updates doesn't mean they all will or should.
The Surge is $249, the Apple watch is $369 ($269 without GPS) and does not count floors. The battery also needs to be recharged daily and you can only pair it with an iPhone.
You can order new bands on Amazon.
Best AnswerSeriously?? for the Surge?? My strapis ripped and i take really good care of mine and dont want to throw it out, so i will check amazon. Thanks so much, hope i find one.
