Do you plan to make all Fit Bit devices compatible with UHC Motion? I paid $250.00+ for my Surge but the Charge2 is the only device you can use with the app. The clip on device that UHC provides is very inaccurate, it fell behind 1500+ steps before lunch time as measured by my Surge which is 100% accurate.
Best AnswerWhen are you going to make the other Fit Bit models compatible with UHC motion. I've got $250.00 in my Surge and should not have to buy a Charge2 to participate. The clip-on unit that UHC provides is very inaccurate and was 1500+ steps behind my Surge which is 100% accurate.
Best AnswerI have merged your duplicate posts.
Fitbit provides a free and open API for 3rd party developers to use with their apps to integrate your Fitbit data with their apps. You would need to ask them (UHC) as Fitbit has no control over how the API is used or whether they use it at all.
