08-30-2016 09:54
08-30-2016 09:54
I suppose one advantage with having a Surge is that there is no temptation to spend an outrageous amount of extra money on a "Special Edition" or a different type of band. Have you seen how much they want for the Alta Gold bracelet? £130 !!! Thats without the Alta!! Staggering.
I guess I'm fortunate in that all I have had to spend is the price of a tube of Superglue to hold mine together.
Best Answer08-30-2016 12:12
08-30-2016 12:12
Depending on how the band broke (out of normal usage) and under warranty, the band can fall under warranty.. (it's up to fitbit to decide).
Feel free to contact the Fitbit Support Team: India | United Kingdom | United States
Optionally check out Returns & Warranty before contacting support.
Best Answer08-30-2016 12:48
08-30-2016 12:48
I think you misunderstood my post...
Best Answer09-03-2016 07:21
09-03-2016 07:21
Hi @Chris1963, how are you today!
Yes, the wristbands of the Fitbit Surge are not interchangeable. However if it gets damage, I find it a little more complicated because then it is necessary to get a whole new Surge.
In regards of the Alta, yeah, besides the price, it is very very cool.
Do you have more comments, feel free to share them here!
