04-01-2018 23:12
04-01-2018 23:12
Where can i do on ths?
is that any service center in Malaysia that i can send for check or change battery?
Best Answer04-02-2018 06:48
04-02-2018 06:48
@BSChee Welcome to the Fitbit Community! I moved your post to the Surge Board as there are more chances for you to receive an answer to your inquiry here.
Battery life will depend mostly on the usage you are giving to the tracker. The age of the tracker may also affect in some cases.
I'd recommend checking these tips to maximize the battery on your Fitbit Surge. This should definitely help you out with this.
Also, there is not a service center in Malaysia in which you can send it to check. The best thing to do in that case would be to contact customer support.
Hope this helps. Let me know how it goes! ![]()
