Hi, is anyone having problems with their surge and MFP. All was fine until yesterday. MFP is not registering my steps anymore and I also dont have the notification panel when I swipe down on my phone. Operating on a galaxy S6. I have unpaired on bluetooth, deleted surge from MFP and fitbit app. Restarted surge and re paired bluetooth and added surge back on MFP but made no difference. Help please.
Best AnswerSame problem on Nokia 6 . Disconnected the tracking, connected again , syncs on the fist synchronisation and then stops again.deleted both apps from the phone (MyFitnessPal and Fitbit) reinstalled again but nothing seems to work. It just updates on the first synch.
You could try un-linking them and then link them back up again.
If that doesn't work then you need to get with MFP
Wendy | CA | Moto G6 Android
Also see this thread.
Apparently MFP is having some problems
Opps helps if I add a link 🙂
https://community.fitbit.com/t5/Blaze/Fitbit-not-syncing-to-MyFitnessPal/m-p/2628919#M95861
Best AnswerThanks. Mine started synching again properly 2 hrs ago. Nothing done , no updates. It seems they solved the issue
