07-18-2016 18:58
07-18-2016 18:58
Best Answer07-24-2016 09:33
07-24-2016 09:33
Hi there @Gerardklein. Welcome to the Community forums!
I'm sorry you're having a hard time with your tracker. I would recommend taking a look at these tips to see if any of them makes your heart rate readings more accurate:
As with all heart-rate tracking technology, whether a chest strap or a wrist-based sensor, accuracy is affected by personal physiology, location of wear, and type of movement.
For all-day wear when you’re not exercising, your tracker should usually rest a finger’s width below your wrist bone and lay flat, just as you would wear a watch. Fitbit’s PurePulse™ heart rate tracking system is designed to be most accurate when the tracker is worn on the top of your wrist.
For improved heart rate accuracy keep these tips in mind:
Note that if you remove your tracker but it keeps moving, for example if you put it in a pocket or backpack, the tracker may display an erroneous heart rate reading. To prevent this by turning off heart rate tracking when the tracker is not in use, log into your dashboard and go to Settings > Devices to turn your Heart Rate Tracking to "Off."
Let me know how it goes!
