08-22-2017
11:20
15:02
MariamV
08-22-2017
11:20
15:02
MariamV
It is showing Fitbit logo and not proceeding beyond. On contacting support they told nothing can be done as warranty is over. Any hack possible?
@DCHK Try letting the battery drain to zero. This would be about 24 hours after the display goes blank. Once that happens charge and restart. Good luck!
Thanks for the suggestion. It worked. Really appreciate But now the problem is date is old 7 and time is weird.
Tried to reboot and reconnect from fitbit account. Nothing happens
Nice input @VF31AE3. Way to go! ![]()
@DCHK thanks for the update. In order for your date to be correct, I suggest syncing your tracker. If you're having issues syncing I recommend checking out this post with further troubleshooting steps.
I suggest trying the following from your Fitbit app:
Let me know if this works!
Did you receive the answer you were looking for? Mark the post as an accepted solution! 🙂
