It's nice to see you around @Gerry-369, hope you're doing great! I'd recommend checking the following articles:
Just to clarify a bit better how the calories will be measured, here are some tips:
Basically, use it as a guide to what changes you need to make to your life to move yourself into your zone and/or towards your goal.
If you are trying to lose weight, the important bit is that the colored bar is shorter than the grey bar. It doesn't really matter if it is green, orange or red. It only matters that you maintain a deficit and you are making lifestyle changes that will allow you to maintain your goal weight when you reach it. There is no wrong rate of loss, just statistics that say slow and steady has a greater probability of maintaining goal.
Hope this helps!
