What happens when you try the restart?
This procedure is known to not always work so it's worth trying again a few times:
http://help.fitbit.com/articles/en_US/Help_article/How-do-I-restart-my-tracker/
05-07-2016
11:35
10:45
05-07-2016
11:35
10:45
Welcome to our Community @natguz! Thanks for joining us!
I noticed @SteveH provided you with some great suggestion to help you resolve this. I'd like to add that you can also make sure your tracker is charging correctly by cleaning the charging contacts on the back of your Surge. Over time the contacts can accumulate dirt and debris that prevents them from making a good connection to the charger. Use a toothpick or toothbrush to clean the charging contacts; do not scrape them with anything metal because this can damage the plating and result in corrosion.
Hope this helps, let me know if it works!
