03-08-2016
03:10
18:42
EstuardoFitbit
03-08-2016
03:10
18:42
EstuardoFitbit
Hi
GPS is an amazing thing, but why does my surge have me running through buildings and fields instead of staying on the road (I aint Superman). My daughters Garmin does not have this problem, is there anything I can do?
Many thanks
Gareth
Best Answer03-08-2016 11:57
03-08-2016 11:57
I've seen that in DCRainmaker reviews. Surge GPS is fairly accurate, but can struggle under difficult conditions like urban and heavily forested areas. From the detailed reviews I've read, Surge GPS overall works fine, but not as good as GPS on running watches from established companies like Garmin.
If you consistently have GPS accuracy problems, then you likely have a bad device and I recommend you contact support and get a replacement under warranty.
04-27-2016 17:50
04-27-2016 17:50
Welcome to the Community @GarethsABitFit! To improve this you can restart your Surge. Another option is using MobileRun. You can combine the stats of your Surge and your phone. To know more about this, take a look at this post.
Hopes it helps!
Best Answer04-27-2016 18:05
04-27-2016 18:05
When I first got my Surge I ran with it on one wrist and my old Garmin on the other. As a general rule they were both accurate, however, that was in the mid spring and as the foliage grew thicker, they both declined in their accuracy. Imagine my surprise when one or both would have me running through the ladies locker room at the local gym and running across a lake on the same run. You may be Superman, but apparently I have properties which make me some sort of a diety. 😛
04-27-2016 20:31 - edited 04-27-2016 20:42
It still amazes me that Gps works as well as it does.
As @shipo stated, if any of these 4 signals get delayed by cloud, tree cover, or a building your walking by, the Gps will be looking at the wrong distance from a satellite, thus throwing the math of
Now let's throw in the fact that your gps receiver clock needs to be accurate to 0.000000040 of a second. Break the second down to a billion pieces, if your off by more than 40 of them, your lost.
