07-15-2017 07:20
07-15-2017 07:20
Hi,
When in treadmill mode on my Surge the HR is showing as much lower than I would expect. I've read that you should position the watch higher up your arm when running but I've tried this and other positions and my HR just seems to sit around the 110bpm mark, even when I'm running at a higher pace. Any ideas? Regards, Rob
Best Answer07-17-2017 09:16
07-17-2017 09:16
Hi, @SunsetRunner, you may also need to wear it a notch tighter and to make that sweat is not interfering with the signal.
Welcome to the Community!
Best Answer07-17-2017 21:53
07-17-2017 21:53
Thanks Julia I'll give that a go.
