It's nice to see you around the Community @cjrmyc
Fitbit trackers have a finely tuned algorithm for step counting. The algorithm is designed to look for intensity and motion patterns that are most indicative of people walking and running. When working at a desk, cooking, or doing other arm movements, the tracker can pick up some extra steps if it thinks you are walking. Many of these situations—such as working or cooking—do include a few steps in-between stationary periods so the tracker tries to give you credit for those steps. For the vast majority of customers, the amount of stray steps accumulated is negligible when compared to the entire day.
For wrist-based trackers, its important to specify whether you wear the tracker on your dominant or non-dominant wrist:
To change your settings, in the Fitbit app go to Account tab and choose your tracker at the top of the screen.
If you feel that your step count and distance are inaccurate, first make sure the wrist placement settings are correct. You may also want to manually adjust the stride length that we calculated automatically based on your height and gender. For more information, see How do I measure and adjust my stride length?
If after taking these factors into account you still think your tracker is significantly undercounting or overcounting steps, please try a step test:
1. Put your wrist-based tracker on your wrist or put your clip-on tracker on your hip or torso.
2. Walk 100 steps, making sure to count a step each time one of your feet hits the ground.
3. Pause, then check your tracker to see your step count.
Fitbit Surge has two ways to track specific exercises. You can tell your tracker when an exercise starts and stops in order to see real-time stats and a workout summary on your wrist. This method, known as exercise mode, also provides GPS. You can also let your Surge automatically detect exercise with the SmartTrack feature. For more information, see How do I track my exercise and activities with Fitbit?
Hope this helps my friend!
