06-04-2020
14:38
13:57
AndreaFitbit
06-04-2020
14:38
13:57
AndreaFitbit
How do I reset my it Everytime I walk every day.
06-04-2020 21:50
06-04-2020 21:50
I do not understand it should reset it self at midnight every night
Is it not doing this?
If it doesn't help try a Long Restart
Plug the device into the charging cable. While the device is plugged into the charging cable, hold the button down for 15 seconds. Remove your finger from button. Note: Device won't have a smiley face icon and should be off with a black screen. Remove the device from the charging cable. Plug the device into the charging cable again. The smiley face icon appears on the screen.
If it does not help contact support. Use the Help link at the top of the forum
Wendy | CA | Moto G6 Android
06-04-2020 21:50
06-04-2020 21:50
