01-01-2016
16:15
06:43
CindyFitbit
01-01-2016
16:15
06:43
CindyFitbit
How do you change the run setting to walk on the Surge?
Hey there, @Yaramir! Welcome to the Family! A warm welcome to the Fitbit Community. That's really strange as that option should be on your Charge 2. Why don't you check in the Fitbit App under > Account > Charge 2 > Short Cuts, if the option "Walk" is listed there.
In case it is, but it is not being shown on the Fitbit Charge 2 options. Let's remove "Walk" from the shortcuts, sync, add "Walk" back to the shortcuts, and sync again. You can force sync by Tapping on "Account" in the Fitbit App, tap on your "Charge 2" picture and find the option "Sync now" to force sync.
Let me know how this worked for you!
Mike | London, UK
Blaze, Surge, Charge 2, Charge, Flex 2 - iPad Air 2, Nokia Lumia 925 (Deceased), iPhone 6
@NeoWhiteYes you can. Tap it until you see walk.
If you want it to be the first you see then go to the Dasboard and under excercise shortcuts move it into first place.
It must sync before it takes place
Wendy | CA | Moto G6 Android
I have the Charge 2....
In my device settings in the app, under the shortcuts menu where I can move around shortcuts like run or treadmill, there is no option for "walk." Thus, there is no walk option when I cycle through excercises on the device itself, either.
Seems like they deleted it or run and walk are essentially the same thing.
Hello @NeoWhite! Thanks for replying. I'm happy to see that @WendyB suggestion worked for you. Feel free to come back for any question that you might have, any member of our family will be glad to help you out! ![]()
If you have time, please check our Discussions board where you will find other members sharing their experiences and tips for an active lifestyle, you might be interested in this topics: Marathon Training or How do you break out of your sedentary lifestyle?
Happy stepping! ![]()
01-10-2018
18:04
08:10
YojanaFitbit
01-10-2018
18:04
08:10
YojanaFitbit
How you can add the walk activity on the charge 2:
Log online, go to your profile, view account settings, click on the charge 2 view device settings, scroll down until you see exercise short cuts, click the down arrow to edit. Click the Edit button, you can select up to 7 activities. After you select the activities, hit save. If you want walk on the top, with your mouse, drag it to the top. This will reflect on your charge 2 once it has synced. ![]()
Moderator edit: Format
How you doing my friend @hdm1961? Welcome!
Thanks a million for sharing this information, it's great to see that you like to help! In this post I'm sharing same information with some other details on how to do it. But feel free to keep adding information on the threads you think its needed.
Thanks for posting and I hope to see you chatting around enjoying the Forums! ![]()
Hi Yojana. I do have another question. With my old Charge HR, I used to see a different display when I tracked my walking done inside the home. Is that option not available with Charge 2?
Thanks for your inquiry @hdm1961! Let me give you some details about it.
You do have that option on the Charge 2, just pressing its button at the end of the activity to see a summary of your results. With each button press you’ll cycle to a different set of stats. You can view your exercise summary one time, the information may vary depending on the activity.
Hope this helps! ![]()
@NeoWhite wrote:Even I couldn't find this option in charge 2. From the app you can set it to walk but not from the device. ☹️😔
You will need to go to the fitbit web interface and log in to your account. Click on your device (Charge 2) to see the device settings. Open ''Exercise shortcuts'', click ''edit'' and then check up to seven exercises (Walk should be among the options). Sync your device. After doing this Walk should appear in exercise menu on your Charge 2.
Hey there, @Frankiefit! Welcome to the Family! Thanks for sharing that information, it's great to know that you are willing to help others. I hope to see more posts from you here.
Happy stepping.
I changed the order of shortcuts. When I move Bike to the top I cannot see walk. (it is listed as second) When I reverse it and put Bike first than walk does not show on my fit bit. It was suggested to remove and then add the shortcut back. But how do you remove them. I don't see that option on the app.
