How do I charge my Fitbit Surge?
Hello everyone! Below you can find the instructions to charge your Surge. We recommend plugging your charging cable into a USB port on your computer or other low-energy device. If necessary, you can use a UL-certified USB wall charger. Don't use a USB hub or battery pack to charge, and only use the charging cable that came with your tracker. To charge your Surge, plug the charging cable into the USB port on your computer and plug the other end into the port on the back of the Surge. Charging completely takes one to two hours.
Plugging charging cable into back of Surge
Your Surge comes equipped with a rechargeable lithium-polymer battery.
I hope you find this helpful.
0 REPLIES 0
