03-11-2016 08:26
03-11-2016 08:26
I'm new to the fitbit, exercise, community and am not up on all the little things. I have a Surge and wanted to export some data to show my cardiologist but have not found a way to read the data I exported. I opened the file w/ notepad++ and it was just an empty HTML shell with no data. I only have the Surge and my laptop, no smart phone, so how do I access this HR data in a useful form?
TIA, Ron R.
Best Answer03-11-2016 13:04 - edited 03-11-2016 13:06
the tcx is empty where no localization exists.
the tcx format file is from Garmin.
no localization, no HR data
Best Answer03-11-2016 14:03
03-11-2016 14:03
Thanks for the quick reply. I took a walk this afternoon and now have a TCX file with data in it. Still have no way of looking at the data in a useful manor. Is there a windows application that can open the file and give me some meaningful data or something that I can use to import the data into Open Office Speadsheet.
Ron R.
Best Answer03-11-2016 16:08
03-11-2016 16:08
@Ron.R wrote:I'm new to the fitbit, exercise, community and am not up on all the little things. I have a Surge and wanted to export some data to show my cardiologist but have not found a way to read the data I exported. I opened the file w/ notepad++ and it was just an empty HTML shell with no data. I only have the Surge and my laptop, no smart phone, so how do I access this HR data in a useful form?
Fitbit has a *bug* with TCX export, it only works if you have tracked a GPS activity using the Surge, or MobileRun, or Blaze with ConnectedGPS. That is unfortunate and I reported a year ago, it still hasn't been fixed.
Fitbit TCX export exists to share an activity with another fitness app like MapMyRun, MapMyRide, Runkeeper, etc, etc.
What exactly do you want to show cardiologist?
03-12-2016 00:28
03-12-2016 00:28
in my opinion, it's no a bug.
the .tcx schema links the heart rate value with position values
http://www8.garmin.com/xmlschemas/TrainingCenterDatabasev2.xsd
i didn't found information in the schema showing it's possible to have heart rate value without position
i can be wrong, of course.
do you know applications generating .tcx with only heart rate values ?
Best Answer03-12-2016 08:28
03-12-2016 08:28
03-12-2016 11:10 - edited 03-12-2016 11:20
in the examples you talk about
There are two examples without any GPS info:
- TCX Fitness History Directory : I don't see heart rate values
- Forerunner 50 #1 : ok, no gps data. but a distance
can you link an example of a Garmin and Wahoo generated TCX file with only heart rate values ?
Best Answer03-13-2016 13:57
03-13-2016 13:57
Basically looks like this:
where each trackpoint includes only timestamp and heart rate.
Best Answer03-13-2016 15:04
03-13-2016 15:04
there is also a distance
in the tcx schema, there is no definition with only a time stamp and a heart rate.
<Trackpoint>
<Time>2007-09-15T12:28:05Z</Time>
<DistanceMeters>2.6250000</DistanceMeters>
<HeartRateBpm xsi:type="HeartRateInBeatsPerMinute_t">
<Value>90</Value>
</HeartRateBpm>
<SensorState>Present</SensorState>
<Extensions>
<ActivityTrackpointExtension
xmlns="http://www.garmin.com/xmlschemas/ActivityExtension/v1" SourceSensor="Footpod">
<Speed>0.3125000</Speed>
<RunCadence>39</RunCadence>
</ActivityTrackpointExtension>
</Extensions>
</Trackpoint>
Best Answer03-13-2016 23:01
03-13-2016 23:01
Best Answer03-13-2016 23:46 - edited 03-13-2016 23:50
@bbarrera wrote:
Please try it yourself, with some other fitness tools. It works. Here is an example https://community.fitbit.com/t5/Surge/TCX-Export-not-working-for-Treadmill-activity/m-p/785171
i will not register to fitness tools i don't need
once more, in your example, HR is not alone, we have a cadence, and it's part of an activity, this definition exists
<Trackpoint> <Time>2015-05-12T23:43:53Z</Time> <HeartRateBpm> <Value>115</Value> </HeartRateBpm> <Cadence>71</Cadence> </Trackpoint>
this definition only doesn't exist
Best Answer03-14-2016 11:56 - edited 03-14-2016 11:58
I really don't understand your question, or your point. You want me to prove something to you? Why do you want to see an example? You have the schema:
<xsd:complexType name="Trackpoint_t"> <xsd:sequence> <xsd:element name="Time" type="xsd:dateTime"/> <xsd:element name="Position" type="Position_t" minOccurs="0"/> <xsd:element name="AltitudeMeters" type="xsd:double" minOccurs="0"/> <xsd:element name="DistanceMeters" type="xsd:double" minOccurs="0"/> <xsd:element name="HeartRateBpm" type="HeartRateInBeatsPerMinute_t" minOccurs="0"/> <xsd:element name="Cadence" type="CadenceValue_t" minOccurs="0"/> <xsd:element name="SensorState" type="SensorState_t" minOccurs="0"/> <xsd:element name="Extensions" type="Extensions_t" minOccurs="0"> <xsd:annotation> <xsd:documentation> You can extend Training Center by adding your own elements from another schema here. </xsd:documentation> </xsd:annotation> </xsd:element> </xsd:sequence> </xsd:complexType>
Source: http://www8.garmin.com/xmlschemas/TrainingCenterDatabasev2.xsd
The schema states that within a trackpoint, only Time must exist (minOccurs defaults to 1). Thats it, a trackpoint must have Time but all other elements are optional, because minOccurs=0.
Therefore you can have a trackpoint with:
- only Time
- Time and HR
- Time, HR, Cadence
- Time, HR, Cadence, Distance
etc.
etc.
There are even tools on the Internet to merge HR-only TCX files with TCX files containing GPS data. Here is one:
http://gotoes.org/strava/Merge_Heart_Rate_TCX_With_Position_TCX.php
And since you keep insisting, here is an example:
<Trackpoint>
<Time>2016-03-05T03:35:56Z</Time>
<HeartRateBpm>
<Value>86</Value>
</HeartRateBpm>
</Trackpoint>I sincerely hope we can stop discussing this, as the TCX schema is explicit that only Time is required element within a trackpoint, and all other elements are optional. Therefore you can have a TCX file with only Time/HR data points, or one with Time/HR/Cadence, or anything else I've previously stated. And I routinely use those files to exchange activities between other fitness apps and websites.
Best Answer03-14-2016 12:03
03-14-2016 12:03
@SunsetRunner wrote:in my opinion, it's no a bug.
As I explained above, the TCX schema clearly shows that trackpoints are only required to have Time. All other fields are optional. Therefore a trackpoint can have Time and HeartRate.
Best Answer03-14-2016 16:08
03-14-2016 16:08
ok , you're right
Best Answer04-13-2017 09:01
04-13-2017 09:01
you can export your tax file and open in google earth. you can then right click the track and see all your data in a graph format
