03-29-2016 04:32
03-29-2016 04:32
If you're in the need of resetting your tracker, you will find the steps below:
Your Surge should now work normally. Hope you find this helpful.
Best Answer03-31-2016 05:30
03-31-2016 05:30
Can do the magic in case not being able to sync, your tracker becomes somehow frozen.. ![]()
