08-24-2017
07:05
07:59
SolangeE
08-24-2017
07:05
07:59
SolangeE
I'm used to the Fitbit charge 2 and when doing workouts I can tap and pull the one I want up. How does the surge work??????
Moderator's edit: Edited title for clarity.
Best Answer08-24-2017 08:03
08-24-2017 08:03
Hello my friend, @Tough50! I have moved your post since you are not referring to a setup issue. This way we keep it more organized. To learn how to use your exercise mode on your Surge, please take a look to this article.
This should clarify all your inquiries about exercise mode and multisport, let me know if it doesn't. 😉
09-11-2017 02:52
09-11-2017 02:52
Best Answer09-11-2017 07:36 - edited 09-11-2017 07:37
@Tough50 wrote:I'm used to the Fitbit charge 2 and when doing workouts I can tap and pull the one I want up. How does the surge work??????
You would press the left button on the Surge; if you're going for a run, scroll to the "Run" app and then press the lower right button; if you're doing a different form of exercise, scroll to the "Exercise" app, press the lower right button, and then scroll through the different exercises (Bike, Hike, Weights, Elliptical, Spinning, Workout), and then press the lower right button again.
