03-03-2016
02:59
16:40
VivisFitbit
03-03-2016
02:59
16:40
VivisFitbit
I used to use Nike + to track my runs which had a voice coach advising pace distance and timecevery 250 metres whilst doing the run. As Fitbit does not integrate with Nike + can anyone advise which integrated running app has voice coach similar to Nike +. I see RunKeeper, MapMyRun and Strava listed do any of these have a realtime voice coach.
Moderator edit: Subject for clairty.
Best Answer@Cimire In a nutshell, the answer is no. I don't wear a Pixel watch, so I did a little searching. This Help article says that the Pixel watch only shows splits after the fact, in your exercise details. So I understand why you want the feedback. Fitbit smartwatches can only give vibration cues, even the Fitbits with speakers.
The voice cues described in this thread come from a very old feature called MobileRun. But MobileRun uses the GPS and other sensors in your phone and it doesn't give heart rate data.
Laurie | Maryland
Runkeeper does.
Im not sure about Endomondo. I deleted it from my phone as I just dont use them any more. But I looked at Runkeeper and it is there.
I just to set it up to do a C25K as well
Wendy | CA | Moto G6 Android
Best AnswerThanks Wendy, I'll take a look at it, are you using it ?
Does it allow you to set voice coach distance i.e. every 250 metres, or 500 meters or 1K advise time, distance and pace ?
Not really sure it does all that. I havent been using GPS on my Phone for a long time.
But Runkepper site is pretty good and answer most your questions
16:45
08:50
04-30-2016
16:45
08:50
Welcome to the Community @RussArrow! That's right @WendyB, here are the instructions to enable the Voice Cues form the Fitbit app.
Hope this helps and happy stepping.
Laurie | Maryland
