03-09-2023 10:44
03-09-2023 10:44
How do I find the total distance I have walked since I started using Fitbit or in a year. Instead of just the average per month or year.
Best Answer03-09-2023 19:55
03-09-2023 19:55
Hi @DominicVales you can always use the calendar on the activities area of the dashboard to find out your steps for any given period of time. While logged in, go here : https://www.fitbit.com/activities. Select the time frame you wish to view and it will tell you the number of steps or distance.
