03-05-2017
07:17
04:35
YojanaFitbit
03-05-2017
07:17
04:35
YojanaFitbit
I have a fitbit surge.
I have 2 alarms saved.
However, I have alarms going off that are not in my saved alarms.
How do I stop these unwanted alarms?
Thanks,
Moderator edit: Clarified subject.
Hi @Emtron56! Please receive a warm welcome to the Fitbit Community! In regards of your extra alarms, have you checked the Setting on your Fitbit? How many is this showing? Make sure that you have only two alarms set. If you already did so restart your Surge. Delete all the alarms then sync your Fitbit, set the alarms again and it should do the trick! ![]()
Let me know how it works! ![]()
