06-23-2018
10:33
10:18
YojanaFitbit
06-23-2018
10:33
10:18
YojanaFitbit
can any one tell me if I can connect my surge to my Honor 5c
Moderator edit: Updated subject for clarity.
You can check the list here
https://www.fitbit.com/devices
Wendy | CA | Moto G6 Android
Hi @Simon85! It's great to see that you've visited the Fitbit Community! Thanks for sharing this link @WendyB. ![]()
I'd like to help you with this inquirie you have! This specific model or the Huawei family is not in the list of compatible devices with Fitbit. ![]()
Sorry for the inconvenience, but we need to be really sure that the Fitbit App will be running flawless, before adding it to the official list.
You can try these steps to make them connect, some users have reported to be able to sync and use call and text notifications in different Android devices that are not in our list, when they update to the latest software. But you'll have to try, as for better practices it's best to sync with a compatible device.
In case that you want to use your PC or laptop you will find the information on how to do it here.
Hope this helps! ![]()
