02-02-2016 05:35
02-02-2016 05:35
02-01-2016 16:27
02-01-2016 16:27
Best Answer02-02-2016 06:10
02-02-2016 06:10
If you're using GPS on the Surge,it does calculate the distance from GPS. Thus, entering your stride length will have no impact on the distance in this case.
Mike | London, UK
Blaze, Surge, Charge 2, Charge, Flex 2 - iPad Air 2, Nokia Lumia 925 (Deceased), iPhone 6
Best Answer02-02-2016 06:24
02-02-2016 06:24
Best Answer02-02-2016 07:39
02-02-2016 07:39
I also have the same issue with distances
I regular run our local parkrun and i currently running with two devices.
My Garmin shows 5.01K
My Fitbit shows 4.74K
Concidering they are using GPS its quite a difference ;(
Best Answer02-02-2016 08:17
02-02-2016 08:17
Best Answer02-02-2016 08:32
02-02-2016 08:32
No its not good, i tried looking at setting my stride length but that seemd confusing to set up as in imperial not metric.
I do understand that different devices have different ways to work it out but its quite a large difference. I really dont want to run with two devices.
Best Answer02-04-2016 17:51
02-04-2016 17:51
Hi, at first, I had a similar issue with the GPS. The cause of the issue is I always pressed quick start and then started running. For me, it fixed the issue if I waited until the GPS loaded. Otherwise, the run will say it started when the GPS signal is found. (which for me in most cases was 2-3 minutes into my run)
Best Answer04-02-2016 04:41
04-02-2016 04:41
I have the same issue with my surge. I did a cross country skiing marathon while recording with GPS and the FitBit Apps (doesn't matter if web, mobile or Win10 App) display it as 29 something km's. Interestingly if you export the .tcx file from the web and import it in an app displaying the track (I used BikeXperience which is freely available) the distance was more or less accurate (43km).
Conclusion: The FitBit surge remains a toy. It just does not perform well enough if you want to use it for serious training. The main issues are:
- Very inaccurate heart rate measurement when doing strenuous work outs (have you guys been able to measure heart rates above 170??)
- Data analysis is very limited in standard FitBit apps
- The Surge can not be easily connected to apps which would allow better data analysis
- Activity data captured can only be exported one by one (*.tcx files)
- ...and a ridiculous bug in gps distance calculation (which actually is present since some months)
